Victor »
https://forums.nicoclub.com/victor-u94029.html
Mon Jul 20, 2009 8:29 am
They are coming to ship my daughters 2000 Q45T to Guam tomorrow and I wanted to do a quick coolant change or at least a partial coolant change before they come. I don't want to open up a can of worms by removing the engine drain plugs or thermostat and possibly causing a leak which I wouldn't have time to fix. Also, I saw a complicated procedure for opening up the heater core, couldn't I just turn the heater on and run the engine until it gets hot?But anyway, I see a rubber plug in the plastic shield covering the bottom of the car. If I pull that out is that covering the radiator drain plug? I don't want to have to remove the whole plastic shield if I can get to the radiator drain plug by removing the rubber plug. Also, is there any plug in the top of the engine for releasing trapped air like on a G20, and if so where is it?
