quick cheep mods need HELP
halfassracing
Car: 1993 nissan 240sx
I have a 93 240sx with a few mods just want some suggestions on what to do. I already have strut bars and small chip no a/c. new motor mounts, new clutch, short shifter, and im going to put electric fans on to get rid of the clutch fan. also im going to bypass the fuel cut. im out of ideas please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Fenvy
Car: 2005 350Z Base 6MT
I really wanted to say stop whinning you noob
but I changed my mind so I'll say that cheap mods really don't amount to much
what's that saying? you got to pay to play or something?
btw that chip you have is junk
miked808
Car: 99 Altima, 95 240sx
Get rid of the chip.Leave the Rev Cut alone.Use the A/C fan untill you get Elec. Toss Mech. Fan now.Tighten and remove slack from accelerator cable. Use 93 octane and advance timing 3 degrees.K&N drop in Filter.300zx Fuel Filter.Check Tire Pressure.Remove intake silencer.Clean all grounds.Synthetic Oil. Redline MT-90 in Trans.Reset ECU.Remove all Sound Deadening material.Use Distilled Water and one bottle of Water Wetter for coolant.Clean Throttle Body, PCV valve and etc... with Intake Cleaner not Carb. Cleaner.Seafoam the Vacumn lines.BG 44k in the Gas Tank.Get a Full Tune Up with good Plugs, Wires, Cap and Rotor.Thats a good foundation to start with, before Expensive Mods.
Modified by miked808 at 7:21 AM 8/22/2005
halfassracing
thanks for all the tips but i have one more question i already cleaned the intake but their was an excess amount of grease and dirt in it, does that sound normal
miked808
Sounds nomal. I would also disconnect the rubber line that goes from valve cover to intake tube and replace with Breather Filter.
Fenvy
halfassracing wrote:thanks for all the tips but i have one more question i already cleaned the intake but their was an excess amount of grease and dirt in it, does that sound normal
I think that's the oil blow by, do a search on oil catch can on here or ebay for more info
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
damn, miked808 has cheap and free mods down!
The only things i would add that are free is: bypass the coolant hose on the throttle body, this is very minimal, but it helps cool off the intake charge... a little.
cams if you got em, maybe a set of S14 and S13?
damn, mikeD nailed it, i got nothin else...
