Quick check on Boost guage-
2projects2many
Car: '91 S13 SR20DET
Alright folks, I finally hooked up a boost gauge today. My question is, when I'm under full boost, the needle is fluttering-is it supposed to do that, or be steady at 7psi. (Sr20det). It just hovers around 5-7- but won't stand still???
Modified by 2projects2many at 8:03 PM 9/19/2009
2projects2many
Anyone?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Perhaps it just accurate and your not used to seeing an accurate display with fluctuation?
2projects2many
So are you saying that it shouldn't be a smooth movement, and sit at the point it's measuring? I just wasn't sure if I was have a boost leak or something that wasn't allowing it to stay constant. It's hard to dial in your boost, if your gauge doesn't stay consistently on a number to know where you're at to begin with.
ZOMG.SR20
Car: 1990 s13
its the boost pressure its supposed to do that, it doesn't hold steady
2projects2many
Thanks for the help! I thought something was wrong. Have 5k miles on this swap, but just got around to installing the gauge, and didn't think that was normal. I see you have an 03 TB, I have an 04, it's been a good truck so far.
Chris28
Car: 92 s13 KA-T
My gauge holds steady. It should not fluctuate under boost. Either you have an intermittent boost leak or your gauge is messed up, more likely it's the gauge.
justclay
Car: 1993 Nissan 240SX SE Convertible
My gauge sort of vibrates at the top end of boost if I hold it there. As far as climbing to and holding certain levels of boost, it should be pretty steady, but at the very top, it wiggles a bit like a fast vibration. What gauge are you running? I've got Autometer.
2projects2many
I don't believe it's the gauge, 'cause I can put a vacumm/pressure gauge on it, and it will hold steady @ 10psi. Must be a fluctuation in boost? I will have to do a boost leak detection I guess.
