Post-up some good pics and we'll take it from there.Hillkill wrote:Ok so my 4th CA was on it's way out so I decided to pull everything apart and freshen her up again. But while I was at my buddies shop he said he had a present for me:) I like presents so he came back a second later with a ca head with tomei cam gears and from what I could tell not stock cams. There were no real marking's on the cams minus 2585n and 2585x stamped on the back of the cams. Also the tomei cam gears are really old because I've never seen them in just light gold anodized. So with what I've researched I'm guessing they are 256 duration 8.5 lift cams. But I would like to see if any of you cam confirm this.
Thanks
can i has them E?Hillkill wrote:Lol at your sig. I easily watched it for at least a minute.
Here are some picsThe cam adjusting hex looks to be half hex and half 12pt.http://i179.photobucket.com/al...7.jpg
The stampshttp://i179.photobucket.com/al...9.jpghttp://i179.photobucket.com/al...8.jpg
Definitely not HKS cams (I have HKS cams) and I don't think they're Tomei's either.themadscientist wrote:Looks like stock cams that have been stamped. They might be reground and those are the shop marks. HKS cams actually have HKS cast in the shafts and either 264 or 256 stamped in the rear and the tail is flat with no indentation.
Those are Tomei cams 256 duration with an 8.5mm lift.Hillkill wrote:Lol at your sig. I easily watched it for at least a minute.
ooop...sorry !float_6969 wrote:You brought a 6 month old post back up? IDK when the last time the OP was even in the forum?
