quick brake answer needed!
BiXLL
Car: ****VERTS**** Black 93--Red 92--White 93
I need to order parts tonight to get them for tomorrow. How do I know if my 92 vert has anti lock brakes or not?
slip69
Car: 94 Nissan 240SX convertible
07 Dodge Charger
if im not mistaken , i believe none of the verts have ABS. its just the front rotors that are from a ABS system. so you will need to get ABS pads for the front and just regular pads for the rear. If im wrong im sure someone will step in and correct me
GoinTopless240
Car: 1993 Nissan Sil40 Vert
2008 VW GTI
2010 Infiniti EX35 bought in 2019 (15,000) miles
Hey BiXLL,Weellll, officially it does not, BUT it does use Anti-lock brake pads (like Slip said just the fronts... the rears are non Anti-lock. Nissan put the bigger pads on the convertibles, but didn't equipt them with anti-lock brakes. If for some reason your car had a "dealer/aftermarket" installed unit, you would see a large controller unit attached to the MC area (Someone pipe in and correct me if I'm wrong). I believe it was NOT an option from Nissan directly with the convertibles. We've seen a few with the dealer installed units. Good luck with the Twins... good to see you got another one..
BiXLL
Thanks fellas, that helps a lot!
BiXLL
Got the front pads changed and 1 caliper changed. Was surprised that Avance had it all in stock. Thanks again guys!
onosqv
Car: '92 240sx Vert
Just fyi, for the rears, abs & non-abs are the same (rotors, calipers, pads).
Basically, just consider verts as an "s13 w/ abs" whenever ordering oem parts from somewhere in regards to rotors, calipers, and pads.
