Quick And Easy Clutch Question
Nesquick
Car: Rb26 Kouki Silvia
k so need a new clutch, not going to get into the story, but i need a new one.
im just not sure if i can use a rb 20/25 clutch and flywheel with my rb26 engine.
here is a pic of my transmission
push type correct????
so basically my question is, can i use the rb 20/25 clutch AND flywheel in my application? :gotme
thanks for the help guys, i searched, found alot of threads, but just couldnt wrap my head around everything
Nesquick
k so i did some more reading and came to the conclusion that i have a push type clutch.
can someone confirm this?
Ramius83
Car: 1995 240sx SE
You have a push type clutch.
The pull type have completely different fork setups......
And yes, you can use the RB20/25 Clutch and Flywheel setup. Or you can also use the Z32 NA Clutch as well.
If you go with a Single/Double/Triple clutch set-up with built-in flywheel, you can use practically any RB20/25/26 Push type clutch, ie: Nismo Super CopperMix, OS Giken, ORC, Exedy.......
