slinger5150 »
https://forums.nicoclub.com/slinger5150-u41428.html
Fri Jul 07, 2006 8:14 am
To do 4 speakers, you would just hook the two left up to the left output, and the two right up to the right output. You'd need to know the ohm rating on the speakers and the ohm rating on the amp.
If you run the two positive leads of say an 8ohm speaker together and the two negatives together, you end up with a 4ohm load. If the amp is a 4ohm stereo amp you're good, which most all amps are. If the ohm level was under the amp rating, you would overload the amp and couldn't do it.
A passive crossover is a separate crossover that you wire in line between the speaker and amp. It is something you would buy separate. The kind you'd buy depends on if you're running highs, midrange, midbass, or sub bass on those speakers.
