t.mcginley.jr »
https://forums.nicoclub.com/t-mcginley-jr-u204971.html
Sun Mar 03, 2013 8:20 pm
While Nissan did get rid of the AIV system after 1992, and probably 99% of Z owners delete them, I think it's actually a pretty cool system since it helps the cats work more efficiently. I actually left my AIV's intact and managed to find someone who had a pair of midpipes made by a muffler shop with magnaflow cats and AIV ports.
As far as I know, none of the aftermarket NA pipes come with AIV ports, you would have to get someone to weld some in (shouldn't be hard for a good welder or exhaust shop). As for temporarily blocking them off, I think it would be better for you to may screen them off instead of actually blocking them. I'm just thinking logically here, but since the AIV tubes are actually pumping out fresh air, it might damage the system if you block them off. If you screen them off (literally with some kind of screen material), it would keep out most debris and still let the AIV system pump air. It would just pump air into the atmosphere instead of your exhaust pipes.
Now that I just wrote all that, I don't feel like deleting it. But I just realized you could probably just put some rubber caps on the AIV tubes and then disconnect the AIV solenoid. That should stop it from trying to pump air. Then just reconnect it when you wanna use it again.
Btw, Magnaflow sells universal high-flow cats on ebay for ~$67 each, in 2" and 2.25" (I think)
