quick ? about sensors inside cab near ECU
POOPmouth
Car: The Devils pimp ride
motor rb20det91 s13 coupe-now car wont idle correct so i took off iac valce cleaned put back on when i turn the key over i hear a click come from the two Green plugs near the rb Ecu- there are Two green plugs and my? is what are they - and what do they control
Sil240
Car: Nissan S13 "The One Cam Wonder"
Hey,Those two RELAYS are supposed to click.You probably haven't noticed it before thoughOne I believe is for Ignition and the other one I believe is for the Fuel Pump.If you pull up the wiring schematic you'll be able to see them.
mello88
Car: s13
Did cleaning the "IAC" (AAC solenoid) solve your idle problem? And yes those relays are supposed to click. Do you have a copy of the FSM?
POOPmouth
no copy of FSM going to order after X-masas for the IAC ( AAC ) i cleaned and car wouldnt start up again- wired?as my cluster engine lights stay on even after i take key out now checked for grounds i was thinking it might be one of those relaysignition -- or fuel pumpits been raning and im sick so ill keep you updated on the status
mello88
Car: s13
Nothing to order, just hit up this site to dl the FSM in PDF format:http://www.speeddreamz.net/mod...cid=1
If that link dies just google r32all.pdf and you'll find it... If you upload the PDF to Fedex/Kinkos they'll print a hardcopy for you for $60 or so, this is really nice so you don't have to run back and forth between the garage and your computer.
