pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Wed Mar 02, 2005 1:46 pm
Well, if the LEDs on the ecu aren't comming on, that means you have a blown fuse some where which powers the ecu or broken 12v wire that supply the ecu with power, but definitely check your fuses.
Look at the foldout pages on the fsm and find out which pins should have power on them when the ignition is on and off.
The ecu Led should turn on when the ignition is turn to the on position.
Good luck,
PULSARGTRRafi
