n240sxfnatic wrote:Open the bleeder a bit, pump the pedal a bunch, close the bleeder, ur done.
what? doing that will do nothing but suck in air through the bleeder.
unless you go pick up one of those one man bleeder kits, bleeding hydraulics is a two person job. with the slave cylinder bleeder shut, pump the pedal several times, then hold it down. have someone loosen the bleeder until fluid "spits" out (due to air in the system). tighten the bleeder. pick the pedal back up and repeat. do this until fluid no longer "spits" out, but just comes out in a stream.
you can make your own one-man bleeder kit with a clear hose and a 20oz coke bottle. connect a clear hose to the slave cylinder bleeder. put the other end of that hose into a coke bottle filled about half way with clean brake fluid (make sure the hose stays submerged in fluid). the shorter the hose, the better. use a hanger to hang the bottle close to the slave cylinder if you need to. loosen the bleeder a little bit and pump the pedal until no air is seen in the clear hose going to the bottle.
WHICH EVER METHOD YOU CHOOSE, MAKE SURE THE RESEVOIR STAYS FULL.
