Quiafe LSD Question - What do I need to buy?
s13eq
Hey guys,
I am about to purchase a Quaife LSD for my open differential 1991 240SX, and I am still uncertain as to what exactly is needed. Would the R200 Quaife LSD be all that I need to purchase? Or would I also need different outputs, or any other parts? Any help would be greatly appreciated, as I've already searched around, and could not find a clear answer.
Thanks!
Exar-Kun
Car: 2005 350Z
THe quaife unit should come with everything you need, including the output flanges, hell..most of the time it comes in its own pumpkin, just add fluid and bolt in.-chet
s13eq
Yes, that would usually be the case. However, Quaife does not make an LSD specifically for 240SX's. I've heard of one or two others using the R200 application, and making it work, but I do not know what other parts they used in the process.
