questtion on dynamat trunk installation
im89
Just want to know if anyone used dynamat in the trunk. Planning on buying the trunk kit but not sure if its good enough for the coupe and does it really work? Thanks.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
im89 wrote:Just want to know if anyone used dynamat in the trunk. Planning on buying the trunk kit but not sure if its good enough for the coupe and does it really work? Thanks.
there are better and less expensive options out there than dynamat! Bquiet-Ultimate and second skin audio's Damplifier or Damplifier Pro are just a few...
you will need about 50 sq ft for the trunk to do it properly, but you should really sound deaden your entire car... that includes:
floors, rear quarter panels, tire wells, trunk, and doors
you will need about 200 sq ft to do the entire car, but it makes a night and day difference. For the ultimate in sound deadening, grab some Luxury liner from second skin audio, and ut that on top of the regular sound deadener
traditional sound deadeners eliminate vribration noise... luxury liner eliminates sonic noise... the two combined together takes your sound deadening to the next level! hope this helps
chrispizzitola
Car: 09 BLK Altima Coupe 2.5s
i put dynamat in the top of the trunk it mad a huge difference only used two sheets
