trynam4size »
https://forums.nicoclub.com/trynam4size-u134225.html
Sat Sep 26, 2009 5:41 pm
Hey Guys,
I did a couple of searches (for pictures) of the differences between the OEM throw out bearing and the aftermarkets, because when I took apart my throw out today, I ran into a couple of issues.
The throwout bearing I bought was a KOYO: look at the pix for number
The KOYO is larger than my old one. Questions:1) what can I do?2) Is there any way around it?3) Could someone point me to someone else who sells the "correct OEM"? (I bought this from phase2motortrend.
Another issue that I found (which I don't have pictures are:) while trying to install my transmission mounts, the "plastic/rubber" part on transmission itself (where the mount is suppose to mate is "cut/destroyed/missing?"
Questions:1) What is this called?2) Anyway of "patching it?"3) Refer to 1) so that I can find shops that would sell em, thanks.
Boost solenoid:(Not really a question)But I plan on running stocked, so I wish to have the boost solenoid. (Want 7psi instead of ~5psi)Is there anyway around it (that won't cost me to drop below 7psi)? This is my first turbo, so I don't really understand the lingo. Can I buy a boost controller to sub for the solenoid (if I do plan on running a bigger turbo in the future?)
BTW: Can anyone identify whats the hard pipe just below the vss (below bottom left looking at the image), I ask because mine was "crushed" while on travel. The one with the black tube/hose.
Thanks,Namco
