a Low Imp is any injector under 4 Ohms they require a resistor pack because the voltage to the injector which is around 13.5 Volts will actually burn out the injector.
A High Imp injector is anything over 10ohms these dont need a resistor pack because it has the built in resistance so that the voltage doesnt burn out the injector.
megamanual wrote:If you are running high-impedance injectors (greater than 10 Ohms), then set the: PWM Time Threshold to 25.4 msec, and the PWM Current Limit (%) to 100%.In essence you are disabling the PWM mode. This allows full voltage to the injectors throughout the pulse widths. For low-impedance injectors (less than 4 Ohms), you need to limit the current to avoid over heating the injectors. To do this, there is a period of time that you apply full battery voltage [peak] current, then switch over to a lower current-averaged [hold] current, i.e. peak and hold. Alternatively, you can add resistors in series with the injectors.
As for the ecu, its configured for low imp. so it has different settings which are needed unlike High imp.
