oversteer180 wrote:Alright I have a few questions....
1. How do i remove my crank pulley? I put it in 5th gear like i was told, and used a 1 1/16 sized socket to try and get it off.. and it seemed like it was making some pretty weird noises...i dont wanna break anything...How should i go about doing this?
2. I ordered some gauges and ahve no clue how to install them...Where do i put the senders for the water temp, oil pressure, and boost gauges?
1.Use the socket and a 'breaker bar', not a ratchet socket driver. Rest the breaker bar handle onto the chassis rail on the driver side. Use a length of pipe over the handle if the handle isn't long enough. Then blip the starter motor with the gearbox in neutral, run the starter for the shortest time possible. This will loosen the crank bolt that holds the pulley on. Getting the pulley off can be harder. Using two big screwdrivers can do it, but a 2 or 3 claw hydraulic bearing puller is needed.
2.- Boost gauge is best tee'd off the back of the plenum.
- Water Temp can be placed inline somewhere (not easy), or under radiator hose.
- Oil pressure needs to be placed in the pressurised line, normally Tee'd off the oil presser sender hole. I would recommend using remote mounting the sender from a tee piece, as the weight of the factory sendor and the gauge sendor can break the tee piece. I saw 2 of these brass tee-pieces break at a recent track day. dropping all of the engine oil onto the track.
Cheers,Chris
