Questions
Q3
Car: Infiniti Q45
What are the biggest rims that can fit on a q45. Also how much and how hard is it to lower a q45. I wanna lower and put rims on mine. thanks
MiniMan
Can you clarify, are you specifically talking rim diameter, or rim width?
Corey
Q3
Car: Infiniti Q45
Like can you fit 20s on the q45
I've seen 18" 'safely' done and it barely fit; search for posts by HeavyDuty. 20" seems nearly impossible without body modification. Also search for posts by OneTonGarage.
pito11213
Car: 2002 Chevrolet Suburban
20" rims fit easy on the Q. I have seen it many time here in NY. Actually 18" rims look small on the Q sometimes. Since you want to lower your ride though 18" rims would look beautiful. Just watch the width of the rim and tire combination. Other can comment better on this than me but I believe 9.5" wide with 255/45R18 would be a nice combo.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Might want to do some reading of previous posts to determine the consequences.
Depends if you want a parking lot queen or a highway performer.
pito11213
No doubt that 20" rims will not give you that super smooth drive. How bad are your roads? 20" rims+ bad roads+ bad shocks= messed up ride
