troll's 240sx »
https://forums.nicoclub.com/troll-s-240sx-u27176.html
Mon Apr 04, 2005 3:46 pm
Ok. Long story shorter, put in a turbo kit that i have pieced out. I rewired my MAF for a Z32, Plugged up my egr because my exhaust manifold does not have a hole for it, ran a Jim Wolf Tech ECU, JWT fuel rail and 50lb msd injectors. With no leaks in my intercooler pipes or my MAF and my Fuel Pressure set at 34psi, the car would run rich and stall it I was to drive it. Now the car would fire one cylinder, cylinder no. 3 only. Checked for spark, and there is spark for all four. Pulled out the plugs and although they look fouled, very black all around, they still throw out spark. I switched the fuel setup back to the stock injectors, stock MAF, with the turbo still hooked up and still it does the same thing. I have tried it with the stock ECU too with the same results. Are there any vacuum lines that I seem to have missed? Oh and replaced the CKP sensor recently because I broked it. I would post up pictures but I dont know how to.
