questions on swapping s13 KADE into s14 chassis
ag240
Car: 1993 Hatch, 1989 Hatch SE, 2010 Fronty SE
*Searched, i couldn't find what i was looking for..
I have a s13 and going to get a s14 chassis, i want to swap the KA24de from s13 to s14. What all mods/fabrication do i need to do to get it to fit/work properly?would the ecu from the s13 work in s14? vice-versa?
also: Would a 01 Frontier KA24 be swappable to the s13? what all would i have to do?
If you find links i didn't, please post them, your help is greatly appreciated
thanks
onosqv
Car: '92 240sx Vert
If you move the entire engine wiring harness & ecu over, no reason it should not work.
Depends on the s14 chassis too, if you are doing it on 95-96 (obdi), should be much easier. For 97-98, it may still work right if you have the harness etc, but if you don't, then I suppose you are just doing the reverse of the guys swapping from obdi -> obdii.
Frontier one, have no clue - but w/ the abudance of 240 KA's, I don't see why you would need to.
