questions on replacing front main seal
Michael.Timz
http://www.nicoclub.com/articles.php?id=242582
^^ using that tutorial as my guide, will i be able to fit a pulley puller and impact gun in between the radiator and the crank pulley?
if not, anybody got any ideas to make this a quick job?
and is it gonna start leaking oil once i pry the old seal out?
r3v_v3ng3
Car: 91 fastback ka-t
depending on how big your impact gun is, you may have to remove the radiator.if you don't want to remove the radiator, you can jack up the front end, remove all the belts. put the parking brake, put it in gear and use a breaker bar with a 27mm (i think) socket. your going to need a lot of force to loosen it. also you don't need a pulley puller cause its not pressed in there. you should be able to wiggle it a little and pull it out.
