First of all, no cable will be damaged in this process... I have sorted out the pinout of the 5-pin DIN cable that connects from the "dealer-installed" infiniti (SONY CDX-5N65W) 10-disc CD changer from 1990-1992 Q45 sedans. If you unplug the cable from the back of the head unit and look at it with the pins facing you, there will be pins at 10, 11, 12, 1, and 2 (clockface). The 10 o'clock pin is the shield for both left and right audio. 11 o'clock is tip for one channel of audio. 12 o'clock is chassis ground. 1 o'clock is tip for the other channel of audio. 2 o'clock is +12V when the CD changer is activated by pressing play on the control unit in the center console. The reason I didn't say "left" and "right" for pins 11:00 and 1:00 is that I never bothered to check which was which. I did my testing with some cobbed together stuff... Now that I know that this will work 100%, I went ahead and ordered some parts to make myself a cable. I ordered some extra as well. If anyone wants a cable to interface the CD changer to an AUX input on an aftermarket deck, email me
[email protected]
