214kka-et240sx wrote:well you don't need and a lsd to start, and welding a diff IMO, is really not a good thing to do, i have seen ppl bracke the weldes on it and fock up the diff, and you will got throught tires more quickly and just driving normal, so just got out and try open diff then go to the next step and get a vlsd or something better
for those who dont drift, yes, you dont need lsd, you dont need welded diff, it does it tires, and they could break. If you are just trying to slide around for ****s and giggles, then yeah, you dont need any kind of locked rear end. If you think you are drifting well on an open diff, then fine, keep it.
For those who actually want to drift somewhat seriously, welding leaves an cheap alternative to a real lsd and the disadvantages aren't as bad as people make them out to be, but the advantages greatly outweigh the bad. I have never seen anyone break a welded diff, i have drifted with 3 personally, and i know of more people with them. If you are drifting, you are eating tires anyways,and its not like you're going to notice the accelerated rate that you are eating them at, so what does it matter. Open diff sucks, i thought it was cool when i had it, but then you find out that its just a ridiculous disadvantage and doesn't contribute to learning how to drift ultimately. You get used to sliding, but that doesn't mean you can't do that on a lsd/welded, its much better to get used to a locked rear end to start with. There isn't any advantage to keeping an open diff other than saving money. If you are worried about breaking a welded diff, buy an extra and weld that a keep the spare open at home just in case, thats what i did, 100 bux maximum to buy a spare and weld it. Worth every penny.
cliff notes: IMO welding a diff is only for those who want to drift and can't afford a real lsd. It's a great thing to do if you are serious about it. I mean people run some crazy stiff coilovers that hurt your back and kidneys but a little chirp when you turn is something to be afraid of? Give me a break.
