J.T.L. »
https://forums.nicoclub.com/j-t-l-u165839.html
Sun Aug 08, 2010 7:23 pm
I'm new to the forum so hi to everyone - I've seen some really nice cars/trucks posted on here.
Here's what I'm working with
1990 Nissan D21 King Cab pickup, 2.4L, 5sp, 2wd, 222,000 miles, 3-spoke Infiniti QX4 wheels with 225 55 16 Kumho ASX's, recent aftermarket shocks f/r
Occasional use (not a daily driver), but when I use it I need to drive it from my parents' house 2 hours away.
The alignment was checked and is ok, but on the highway or any 45mph+ roads I need to steer it a lot just to keep going straight, which isn't the case with my newer car. I'm not turing the wheel 90 degrees or anything, but frequent adjustments or maintained pressure left or right is needed. My plan was to replace all the rubber bushings in the front suspension, steering linkages and sway bar with new factory bushings to get it back to where it was when new with hopefully no "wander" at speed. I was planning to stick with stock parts (not urethane) since I'm not offroading or using it hard, and although I like it I'm not expecting to keep it for another 222k.
Questions are does this sound like an expected condition for the mileage, and will replacing the rubber bushings fix the problem or should I look in a different direction or look at replacing something else in addition?
Also, while I'm asking suspension questions, Nismo lists front/rear sway bars for the D21. The front already has a (1"?) sway bar, so I'm wondering if anyone who has the Nismo bars front and/or rear can comment if they noticed a difference/improvement in handling over stock.
Thanks in advance,
J.T.
1990 Nissan D21
1972 Datsun 510 L16, Z 5-Speed
