whoflungpoo »
https://forums.nicoclub.com/whoflungpoo-u8813.html
Mon Nov 26, 2007 12:20 pm
you guys are really gonna make me go crawl under my cars again aren't you?
it's raining out now, but I'll get some comparison pics of the cross member later, but I'm pretty sure that they fit.
yes the pedals are slightly different from the 13 to the 14. it has to do with the bracket that spaces the MC and the pedal. IIRC, the S13 is built into the firewall, and the S14 is on the pedal assembly itself.
I had to shim the 13 pedal that I installed on my S14, but it worked. if you have the 14 pedal, you may have to grind that part off.
