Postby
bobbychet »
https://forums.nicoclub.com/bobbychet-u105513.htmlWed Oct 06, 2010 9:23 am
Hi
I was wondering if the Ser's with the Rockford Fosgate sound systems had outputs for adding a amp.And who has run amp wires? how and where did you get through the
fire wall? I have a 2008 sentra
thanks Bobby
Postby
PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.htmlSat Oct 09, 2010 9:31 am
Factory systems usually don't have axillary outputs, but you can wire it up in other ways. There is usually a grommet or 2 in the firewall that you can run your main power wire through... or you can drill a new hole.
Postby
bobbychet »
https://forums.nicoclub.com/bobbychet-u105513.htmlFri Oct 29, 2010 9:39 pm
I'm trying not to drill and heard there's a plug on the firewall behind the airfilter housing .
I pulled my rear seats as to find mount points and route speaker wire to my drivers seat.
That's where I'm installing my amp since I don't have a bluetooth box . So now I've pulled my front seats pretty much as far as I can without disconnecting the harnesses. Took a T-50 socket to remove the front seat mounting bolts. I've tapped into my Rockford Fosgate speaker inputs with a line out converter and will try to route the power cable through the firewall tomorrow.
I'm tired
Bobby
Postby
bobbychet »
https://forums.nicoclub.com/bobbychet-u105513.htmlSat Oct 30, 2010 8:19 am
I have a question though
I've tapped into my front and rear speakers for the line converter,but I'll need a switched on signal for the amp.Any ideas where this ACC signal is located? I've tested most wires and can't seem to find it.
Bobby
Postby
bobbychet »
https://forums.nicoclub.com/bobbychet-u105513.htmlSat Oct 30, 2010 9:38 pm
well the audio converter has a blue/white wire for the remote turn on.
No way Nissan has anything close. I found a green wire on the big plug that was acc switch. Systems in but still needs adjustments.
I'm Bushed.
Bobbychet
