1) They are different thread about the CVT noise. Some are du to gear change or something like that, but not for everyone. I have a Rogue 2009 and I didn't have this problem. Others find that the CVT, even when it's normal, they found this noisy. If you test drive is succesfull, stay with this idea.Decryption wrote:So I am getting ready to pull the trigger on a new 2012 Nissan Rogue SL, but I have a few questions that the dealer was unable to answer.
So my questions if you wouldn't mind answering are as follows:
1.) Does anyone who has a 2012 know if the CVT noise has been eliminated?
2.) Does anyone know if there is a 2013 coming out with a turbo? If so would you mind showing me where Nissan or facts of this are coming from?
3.) I have an Android phone, I have searched through the site but I don't see where the Nav kit will work with an Android phone. Does anyone know if there is a firmware upgrade for the USB connection to read, or will I have to get an aftermarket head unit?
4.) How hard would it be to put an automatic liftgate system on the Rogue?
Please accept my apology if any of these questions have been answered and I did not use the search correctly to find my answers and Thank you to anyone who responds to my answers.
Our 2008 doesn't have this problem either. I'd second kerrton's comment on this matter.koolyce wrote:I have a Rogue 2009 and I didn't have this problem.
Paved roads are still paved after snow. They may not be plowed...Decryption wrote:To top it off it when it snows the roads do not always get paved.
Point taken, sorry I didn't think my statement out before typing it.takeshi wrote:Paved roads are still paved after snow. They may not be plowed...Decryption wrote:To top it off it when it snows the roads do not always get paved.
The MPG is related to your driving style mostly.Decryption wrote:Thank you for the response Koolyce. I did go through the fuel consumption logs and I see that it varies. I did come from several sports cars (350Z Nismo) being the last one, so I've dealt with bad fuel consumption. However 17-19mpg seems far below the advertised consumption. May I ask if you are in a warm climate or doing altitude driving?
I would keep a very close eye on the new 2013 Altima and Sentra. They should be revealed this spring. Whatever engine powers these models will most likely appear in the Rogue as well.kerrton wrote:The new Rogue will have a new powertrain, likely a small dispalcement turbo as an option around 1.8 or 2.0 L most likely. I would guess that also the current 2.5QR engine will continue as the base powertrain at least initially but it may get re-worked as well.
I drove in Montreal, Quebec, so I have winter. I did different test and honestly, even if I drive smooth on the highway, summer or winter, with or without AC, my consumption is always over 10L/100km.Decryption wrote:Thank you for the response Koolyce. I did go through the fuel consumption logs and I see that it varies. I did come from several sports cars (350Z Nismo) being the last one, so I've dealt with bad fuel consumption. However 17-19mpg seems far below the advertised consumption. May I ask if you are in a warm climate or doing altitude driving?
