Thanks. I'm pretty religious about changing oil and other fluids. I use Mobil 1 Extended Performance oil, and I NEVER start the car unless I'm going to drive it long enough for the oil to completely reach normal operating temp. Accordingly, I change oil every 3,000 miles or every four months, whichever comes first. I intend to flush the trans every year, and flush the cooling system, steering system, and brake system and engine cooling fan fluid every two years, regardless of if the owner's manual recommends longer intervals.Q45tech wrote:We have about 8 -- 2002 and later Cima customers plus an assortment of early M45 customers.
All I can say is to change every filuid and filter frequently................be sure to follow the 90 day oil change interval..............especially since it appears you only drive 12k per year.
You might find some interesting pictures in the VH/VK portion of forum showing the lightening of the piston and rod components in your engine.
Do you really want minimum wage pit monkeys working on your Q45?mhoepfin wrote:Question on oil changes - Any issues having a run of the mill Jiffy Lube place do them?
Mike
Yes, lots of issues. They tend to do very poor work - period! Leaving out heat-shields, not changing drain plug washers, screws, etc.mhoepfin wrote:Question on oil changes - Any issues having a run of the mill Jiffy Lube place do them?
I buy my own Mobil 1, then take it to the dealer. For $20, I get the oil changed (using my oil), a new Nissan Oil filter, new crush washer, drain plug and filter torqued to Infiniti specs, a complete inspection of the car bumper to bumper including brake pad wear, with written report, tires checked for pressure, wear, and wear patterns, all other fluids checked and topped off if necessary, and when finished, they wash it and clean the interior. Meanwhile, I sit in a beautiful waiting room eating their free donuts and sweet rolls, drink their coffee with whatever kind of sweetener or flavored creamer I want, or hot chocolate if I prefer, as much as I want of all of them, and read all the latest of their car magazines. Hard to beat.szhosain wrote:
What I do is buy my own stuff (6 qts of Mobil 1 Synthetic 0W-40 oil, and an OEM oil filter and a copper crush washer from http://www.everythinginfiniti.com) and then take everything to local shops (Goodyear Auto Center or Precision Tune typically) and watch them do the work properly.
If I had a lift, I'd do my own oil changes for sure.
Z
I know the tech who is the only one I let work on my car. He would never do that to me. Sometimes you just gotta trust pelople you do business with. Fact is if they would do something like that, they could just get young kids to do other work. They don't. And any place that changes your oil can substitute junk for good stuff unless you stand and watch them. Not worth the trouble for me. My dealer has alway been very good to me, and at least to my knowledge doesn't pull stuff like you mentioned. Whenever they do use subcontractors, they tell me in front. I've been in their shop, and have only seen trained techs changing oil and doing repairs.qship96 wrote:Dont be so sure who is changing your oil at the dealer-all dealers hire semi skilled labor{young punks} to complete simple jobs like oil changes-they dont use factory trained techs for that! and how do you know that synthetic oil is ending up in YOUR engine,not the souped up civic that same flunkie drove in to work with?
Good points. You have to watch. the deal is none of the Jifffy Lubes types are familiar with a Q45, and even getting them to remove the under engine tray can be a struggle.qship96 wrote:Dont be so sure who is changing your oil at the dealer-all dealers hire semi skilled labor{young punks} to complete simple jobs like oil changes-they dont use factory trained techs for that! and how do you know that synthetic oil is ending up in YOUR engine,not the souped up civic that same flunkie drove in to work with?
If I could get the Infiniti dealer to do all that for $20, I'd use them too! Unfortunately, locally, they want closer to $50 for all that. So, all my "in-between" oil changes are done at local shops, where I can supervise the work. This oil change labor costs me $10 to $12 - depending to which place is available (I call ahead).StarPD wrote:I buy my own Mobil 1, then take it to the dealer. For $20, I get the oil changed (using my oil), a new Nissan Oil filter, new crush washer, drain plug and filter torqued to Infiniti specs, a complete inspection of the car bumper to bumper including brake pad wear, with written report, tires checked for pressure, wear, and wear patterns, all other fluids checked and topped off if necessary, and when finished, they wash it and clean the interior.
Probably.mhoepfin wrote:Intersting replies..
So would a Nissan dealer be acceptable for an oil change rather than the Infiniti dealer?
More than you might think, I suspect!mhoepfin wrote:I've got to wonder what percentage of luxury car owners use the dealer for a routine oil change rather than a Jiffy Lube type place?
Not for some people, I suppose!mhoepfin wrote:There's generally a high level of inconvienence going to the dealer for this, no?
If I had a safe way to get to the oil filter and plug, then I'd do my own oil too ... I don't like the idea of using stands with a 4000+ lb car ... could be scary!Q45man1 wrote:I'm the poor guy here.I change my own oil for all my four cars. All synthetic. I have my stock of OEM oil filter and crush washer. Take the used oil to Kragen or Autozone. And have time to play golf in the weekend
Most Nissan dealer technicians have never worked on a VH45DE since it was exclusive to the G50.mhoepfin wrote:So would a Nissan dealer be acceptable for an oil change rather than the Infiniti dealer?
One of the Infiniti recommended procedures to reduce carbon buildup is to put the car into neutral, and rev the engine to redline a few times and let it run at 5,000 or more rpm for a short while (I forget how long ... I should go look it up).elwesso wrote:Honestly I dont see the problem with regular redlining. That actually helps keep the lower end of the intake tract clean...
