This one sounds like a worn out transmission mount, aka 3rd engine mount. My vibration was at about 45-55mph and then again at 65-75mph and at around the 2250 rpm range. At 115k on your Q you're about due. Replacement takes about an hour and is very straightforward.bgerner12 wrote:- I get a fairly high-frequency vibration that starts at around 35mph and is gone at around 65mph. It comes back worse once I get above 80mph. This does not feel like a wheel/tire and placing the transmission in nuetral (rpms drop to idle) while at speed has no effect.
Anyone recognize these symptoms and know the cause?
Lubeguard Red is great stuff. I've used it in a couple of hard shifting trannys with great success.bgerner12 wrote:.....Only the huge speed bumps at mydaughter's high school can get the slightest creak and I suspect that maygo away with time. All the other weird behavior of the suspension is gone.
How did the rubber look in the exhaust hangers attached to the transmission mount? Still bonded to their bracket? Not torn?bgerner12 wrote:......The transmission mount looks real healthy so it seems less likely that it is the cause.
Mint- I got your PM, but i can't reply to you (maybe you have disabled PMs?)Mint Q45A wrote:Multivalve...I have exactly the same issue since I replaced the accumulators. I went through the trouble of disassembling the MV, but everything looked ok. I haven't had the time (or the money) to look more into this. For some reason I believe the vibration is more some sort of resonance coming from the hose that goes between the reservoir for the Active fluid and the pump or multivalve.
Mint Q45A if you are still around...When you took apart the multivalve did it work as it did before you took it apart. I am trying to see if the Multivalve is fixable if broken or is it like a ABS Actuator.Mint Q45A wrote:Multivalve...I have exactly the same issue since I replaced the accumulators. I went through the trouble of disassembling the MV, but everything looked ok. I haven't had the time (or the money) to look more into this. For some reason I believe the vibration is more some sort of resonance coming from the hose that goes between the reservoir for the Active fluid and the pump or multivalve.
