Questions for Meggala or anyone that knows about RB30DET
93RPS13
Car: Cars, Girls, Cars, Food
i have a question for meggala i thinking about the RB30 oil pan, if the oil pan is different from the RB25 then the mckinney mounts would be useless the oil pan would hit the sway bar, so are the RB30 oil pan the same or simiar as the RB25, can the RB25 oil pan bolt up to the RB30 block and would it be sufficient(sp?)?
also are there any website that can help me with the RB30DET conversion other than the one on your website??
Thanks for youre replies
TropikalSX
Car: Hott girls, 240SX
You can use RB25, that is the one I'm using.
93RPS13
so the the RB25 oil pan bolts up to the the RB30 block right? Double checking
Thanks
TropikalSX
Yep. fo shizzel
93RPS13
thank you mi nizzel...lol
93RPS13
TropikalSX
93RPS13
yea... i read almost everything about the RB30 thanks anyways
McAdam
Car: I like cars and my motorcycle. boats are fun too
you should have checked here I beleive that is the info you are looking for.
McAdam
93RPS13
yea i read everything that is related on meggalas website
93RPS13
does anyone know anything about ceramic coated cylinder walls to reduce heat in the engine also it is expensive?
how thick are RB30 head gaskets?
TropikalSX
You may want to do some more research outside of this forum. General info like that can be found easily by doing a search on google.com etc.
93RPS13
meggala
there is very little written bout the rb 25/30 I only put the informationon my site as a guide and personally wouldnt do the rb 25/30 combo. you really jsut need to use google. the rb 30 has a simialr sump to the rb 25 so it shouldnt be a problem
cheers
93RPS13
sump mean oil pan right???
93RPS13
yea i just registered on some aussie forums so i can get some info on it.
meggala
Quote »sump mean oil pan right???[/quote]
yep
93RPS13
meggala do you know if the RB25DET engine harness plug into the RB30 engine?
