Questions for Coupe owners w/Tenzo wheels
All things Altima Coupe.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Can anyone share where they purchased their hubcentric rings? The ones I received with my package are stamped 66.1 to 73 and they dont fit. There is play on both the hub itself and on the interior of the wheel inside the tapered bore. Basically I was given a free set of cheap, inaccurate, metal rings. I need something quality, that extends a little further off the hub than normal, and hugs the hub tightly.
For those of you who are wondering why I ask, I have had an ongoing problem since I purchased the wheels with vibration, this has been determined to be the end all be all.
DJ_B_Easy
Bump...anyone?
Ranga14 out there? Someone else just bought Cuzcos too, red lip?
Ranga14
Car: Boosted 08 Altima Coupe 3.5
I never purchased any. After my re balance the vibration went away. Where did you go to have the wheels/tires put on? Did they not have any to purchase?
DJ_B_Easy
Tires came mounted on the wheels and I was given a set of rings from Discount Tire. They are crap though, they are marked with the correct size, however they dont fit snug on the hub and they fall too far into the wheel bore to be effective. Did you notice how deep the taper was on the inside of the Tenzo wheels? They are falling completely inside of the bore and not sitting flush with the outside surface of the wheel.
So you arent even using any rings? Guess Ill give that a try, thought that was a terrible idea though. Now that I think about it, if my rings are sort of floating in limbo inside my hub and wheel bore they are probably whats giving me the vibration in the first place.
Thanks for chiming in.
Mr.Coupe
Car: 08 Altima Coupe 3.5 BOOSTED
If you're still looking for Hub rings you could check out this site dude...
http://www.justforwheels.com/index.jsp
Goodluck with the problem and I hope you get it fixed. It would drive me crazy as well if it were happening to me.
Ricky C. :dblthumb:
DJ_B_Easy
I actually just bought a set of off eBay. They looked to have a bit thicker taper from the hub to the interior of the wheel and thats exactly what I need to sit the wheel properly. If they dont work out, I'll check the other site.
Thanks.
