Questions for Cali coupes who have y pipe or header
All things Altima Coupe.
legend_217
Car: 08 Altima Coupe 3.5 black
How do you manage to pass the smog test when you have to go thru visual test ? I'm about to order y pipe, but don't want to take it off every time I do smog check. I don't have any necessary tools to lift my car, especially with coilovers installed Any advice
Rob.Vegan
Car: 08 2.5S Altima Coupe 76 Datsun 280z (not running)
Smog check isn't too often is it ???
I have headers and am planning on just switching back to stock when smog times come (unless I don't have to )
legend_217
That just sucks
KilaDragN
Car: 08 Altima Coupe 2.5 MT
California smog check is usually every 2 years?(i think), and if you fail a smog test, they usually send you to get smog every year. Test Only smog centers are usually a little more strict than regular smog shops.
if u know a shop, they usually pass you on visual inspection. but if you don't. the only thing you need to change back is the headers. they don't usually lift up your car to do a smog test. so the Y-pipe should be fine for the visual. I'm not sure how it will affect the actual smog test itself though.
