mcheddadi »
https://forums.nicoclub.com/mcheddadi-u65598.html
Tue Sep 18, 2007 4:29 pm
I think I found my answer:
Traction Control System (TCS)
•TCS is standard on Pathfinder Armada and optional on Titan.
•The traction control system reduces torque to the drive wheels by altering injector pulse and controlling the Electronic Throttle Control (ETC) motor. If necessary, the brakes are also pulsed via the ABS control unit and hydraulic unit to reduce slipping.
–For injector pulse and ETC functions, the ECM receives wheel slip information from the ABS control unit through the Controller Area Network (CAN) bus.
TCS operates at all speeds and limits drive-wheel slip (wheel spin) under most conditions, improving driver control of the vehicle in slippery conditions as well as on dry surfaces if throttle is over-applied.
Vehicle Dynamic Control (VDC)with TCS and ABS
•The VDC system is standard on Pathfinder Armada. The system integrates ABS and TCS with additional cornering controls.
•The VDC control functions (integrated into the ABS control unit) monitor the input from steering wheel angle, vehicle speed, wheel speed, G-force and yaw rate.
•When vehicle stability is affected by road conditions or the need to make an emergency maneuver, the system helps to maintain optimum speed at each wheel.
•The system controls engine output by reducing fuel and throttle opening,and provides individual braking control for each wheel to reduce or prevent skidding.
VDC changes engine power and/or applies the brakes individually as necessary to help stabilize the vehicle in severe turning situations. VDC helps enhance performance in emergency avoidance maneuvers, helps improve vehicle directional stability, and helps provide improved control even on slippery road surfaces.
Note:VDC not available with locking rear differential.
So correct me If I'm wrong but since nissan has the same VDC for all it's cars, then I'm guessing that the VDC for the altima coupe incorporates TCS, so that's why when I get VDC I only have a VDC button, an not another TCS button next to it.
What do you guys think?
