miata007 »
https://forums.nicoclub.com/miata007-u31566.html
Tue May 12, 2009 6:54 am
Hi all,Working on check engine light issue over the weekend after OBDII purchased from Walmart ($100).
Have few questions here:
1. According to FSM, need to have access to the ECM connector. I've took out the glove box and found the ECM. Problem was I couldn't remove the ECM harness protector. The was only 1 bolt which I've loosed but there was a metal/frame/bracket on one end that kept the protector from coming off. Addition item/brackets need to be remove in order to get access?
2. While the glove compartment is out, I've decided to finally replace the cabin filter. Couple problems here. Does the car comes with 1? (yr 1997) If yes, can someone provide more details on on how to get to it?
I've did a search on cabin filter and found many response from (maxnix) saying this topic has been discussed before but couldn't find the details instructions. It is not in my FSM perhaps I have an older version.
3. Back to the DTC code, the scanner gave me 3 codes all complaining about the throttle position sensors. P1020 TPS P1705 TPS AT P????? can't recall the code now but it mentioned: TPS and Tandem.
Anyway, according to FSM again, it recommend me to start out with P1020. I've skipped the ECM voltage measurement part as I couldn't get access to it. I proceed to the next part and start measuring resistance of the TPS (EC120). Here are the results (engined warmed up):
Conditions Expected MeasuredThrottle (ohm) (ohm)-------------- ---------------- -----------------closed .6K .6K open 5K 3.33K
3.33K vs 5K(expected), it is off quite a bit. As a result, FSM suggests to replace the TPS. I've decided to order the part from Joe despite the fact that I have skipped the ECM testing part. Any one has replace this sensor before? I appreciate any tips in working with this issue/code.
4. One last question. In FSM, for each connectors they mention T.S. and H.S. I believe they stand for terminal side and harness side. Can someone please confirm and explain. I got confused following the FSM.
Thanks for reading and all the help!!!
007
