DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Oct 02, 2005 6:47 pm
i see....
because the lights just shine directly onto the clear plastic peices that transfer the light to the different things, similar to a fiber optic cable. I wonder how hot they can get before they start to burn
then again which do you think can handle more heat, the little plastic caps or a much thinker piece of solid acyrilc or plastic, whatever it is.
all i got for you is, mine are still just fine, maybe you should just try removing the blue things and see how you like it
