BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Thu Dec 19, 2002 8:51 pm
Ugh, I can't believe I'm getting roped into doing this, but I'm going to be the brains behind this operation, except for the wiring, you are on your own.
Anyway, I'm going to make him replace the F + R main seals, and the thermostat, can those be gotten off of a NX or Pulsar or whatever it is that interchanges? What about the water pump?Does the CA18's o2 extension have the AIV fitting that needs to be removed, like the SR20?
EDIT: Does he also need to swap out the tach from the CA18 clip into his cluster, it's an 89.
