Questions before I increase boost.
hotbox240
Car: 92 Hatch 5spd KA-T
Sup guys,I plan on upping the boost on my current turbo setup but I have a few questions before I do. I finally recieved my 480cc injectors in the mail (I know I know I should of gone bigger). But I'm worried there not gonna fit in my stock fuel rail. The stock 270 is on the right and the 480 is on the left (still need o-rings). Can anybody verify?
My other question is about my turbo. I'm currently running a 57 trim with a .48 AR exhaust side. How much boost can I run before this becomes restrictive and I need a .63?
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Are those S15 480's?
hotbox240
redtop91 wrote:Are those S15 480's?
Indeed they are.
redtop91
They'll work.
480sx
Car: 1996 Pearl White 240sx
Your injectors are fine, they will fit in the stock rail. Id use new o-rings.
Your turbo setup is good too, 480's will max out before the turbo becomes TO restrictive.
hotbox240
How much power do you think these injectors are good for with a safe duty cycle?
redtop91
At an 80% duty cycle I'd venture for right around 300-310.
NateDogg
Yah you'll want to check your duty cycle at over 12psi.
Jookmasta
agreed, i think that 480s will only be good for 300-320rwhp. and yes you should've gotten bigger injectors.............
