andrave »
https://forums.nicoclub.com/andrave-u6358.html
Mon Jun 14, 2004 3:36 pm
you will prolly need custom lines to do it that way. it would be hard to keep it thought, the AC compressor gets in the way. But you could try it the way it is. The lines will be fine by the turbo, so unless they get in your way you could try it.
as for Z32 brakes you need the adaptor lines because the z32 brakes use a different fitting, and you need z32 rotors redrilled to 4 lug. and you will need aftermarket wheels prolly too, I don't think the stock 15's clear on an 89.
