gpelite »
https://forums.nicoclub.com/gpelite-u31517.html
Tue Jul 11, 2006 7:04 pm
Not a pro on the TT set up, maybe the TT guys can help me sort out the way nissan put her together. Some of this is from my last posts, but when I split the posts up seperately, ppl dodged all but one completely. I need advice!
I got an oil cooler with my TT oil tree. I was wondering when Twin turbo oil tree gives oil to the cooler, does the cooler outlet empty back into the oil pan? I noticed a little inlet on the pan besides the main oil retuns for the turbos, is that where the cooled oil goes after it goes through the cooler? most sandwich plates route back to the tree, but I see no such way with the TT tree. Whats the route of oil there?
Also could I route my turbo oil supplies off the tree? I know I COULD, but would it work well enough? I see everyone doing it for turbo upgrades, is there a better way? On that note also Can the oil supply be from the tree->turbo-> and return to the pan without a huge pressure change? (usually when ppl add turbos to a previously non turbo engine everything routes back to the oil tree for some reason I have seen with sandwich plates and such, I assumed it was to keep pressure or lack of a modified oil pan to fit return needs, whats the verdict on that?)
I realise the TT and N/A pumps have a 30psi difference from what I hear, I know it can be done with an N/A oil pump, I have seen it, but is it going to give the basic needs to my engine for now? changing later is on the list of course
How large of injectors could the N/A fuel pump handle? I have the 370cc TT injectors, but will the N/A pump handle it well or will it need a booster pump? What is the max cc injector the stock N/A pump can handle?
I will be adjusting air/fuel ratio with with apexi afc.
PS. I don't need the N/A vs TT speech, I know its limited in many ways, its just a free time conversion project. Just let me know about the above, part or all if you can, thanks in advance
