zmannz »
https://forums.nicoclub.com/zmannz-u23244.html
Tue Oct 11, 2011 7:59 am
Hey guys, I have a 95 s14 I just picked to dd for the time it takes to build my other car. It's an AT with about 194k and it has been babied. No mods, and I knew the last two owners. It ran great at first but quickly developed an issue with the fuel system (now fixed with a 255) and then the coil in the dizzy (new one on there now). I was driving it again after this, and now the waterpump is leaking. I have decided to go ahead and hit the front end of the motor with everything it needs while I am doing the water pump. I plan to replace the timing chain and associated parts and the water pump while in there.
All the quality recommended timing kits include a chain, tensioners, and guides. For some reason all the cheap ones also include the gears. Do I really need to replace the timing gears too? The chain and gears in mine appear to be in great shape. I am looking at spending right under 500 for the oil pump and timing kit from FRsport as it is, and adding the gears would easily be a few hundred more dollars. I can buy a whole extra motor and trans with only 120k miles for 600 that would only need a water pump for piece of mind.
Another place I found that intrigued me was importperformanceparts.net. They have oil pump rebuild kits, and they also sell high volume new pumps. The timing kits there have the gears and run 250, and they are top line brand which I have been told is good, BUT that kit includes the rail that nissan has since discontinued for the ka24de. All in all I can get the oil and water pump and the timing kit there for 600 including a high volume oil pump. They also have rebuild kits for the oil pump but honestly I am a little skeptical about that unless I hear its as reliable as buying a new one. The motor hasn't failed so I suppose the existing pump housing is in pretty good shape. I get good oil pressure all the time. anyway, I am ordering this stuff today, I would love some input about which way to go. Thanks in advance!
