Questions about swapping an S15 SR into a Datsun 510
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
510NUT
Car: 71 510 DATSUN, 02 SE-R SPEC-V
ANYONE KNOW HOW HARD IT WILL BE TO SWAP A S15 IN TO 71' 510 ?IS IT LIKE A SR20DET (S14-S13) OR KA24DET .I'M THINKING ABOUT IT .......
PLZ HELP THANX
Modified by 510NUT at 8:58 PM 10/24/2007
Modified by 510NUT at 3:57 PM 10/26/2007
ehop
Car: 71' datsun 510 4 door
not sure how hard it is but people do it all the time
Mig
Car: 1978 280Z, 1979 810 2dr, 1964 L320 Pickup, 2006 Chevrolet HHR 2LT
Not really sure what you mean. S13, S14, S15 are platform designtions while SR20, KA24, etc. are engine designations so I don't really understand your question or what it is that 'ehop' says people do all the time.
ehop
hes just talkin about swappin the motor into a 510. sr20 is a popular swap for a 510, lots of rotary's too.
Mr1der
assuming he's talking about an S15 SR...about like putting any other SR in...just gonna cost more....
theharlequin
Yes it's a popular swap. But difficulty is definitely on medium to high. The subframe has to be swapped out along with other components. There are a few builds on the board talking about it. I know i keep referring to it, but mesojdm's build has a lot of details and lists all the stuff he's doing. Plus research helps in general too <_< >_>
slowpoke240
anythings possible with the right amount of $$$
Mig
So you're talking about swapping the FWD engine into a RWD car. Why do that when the RWD SR20DET is available? Like slowpoke240 said, anything is possible with the right amount of $$.
510NUT
THANX FOR THE INFO
Godzilladat
Car: Volvo
I can't comment on the LHD 510's, but the RHD 510's in australia it's as easy as the following;
reverse the crossmember (this means reversing the whole crossmember to accomodate for the rear facing sump, as well as reversing the control arm pin holes as 1 side is tapered)use standard S13 SR20 engine brackets add 10mm spacers to the exhaust side bracket and BOLT in the engine
For the gearbox mount, use the S13 gbox mount and drill new holes in the floor.
You will also need a custom sway bar, and on the RHD model you need a reversed steering drag link.
Since all your steering is on the left side, you'll have to work out the exhaust manifold stuff, this is where I'd look at the mesojdm thread for ideas.
Alternatively you could buy a pre-made kit from australia and get it shipped over, some places below that can help;
http://www.datsport.comhttp://www.swmot ... dat.com.au
Good Luck.
Modified by Godzilladat at 9:59 PM 11/5/2007
Mr1der
god I hope you have tons of pictures of your FJ powered car.
Godzilladat
Car: Volvo
Yep, got a few, anything in particular you wanted to check out?
Mr1der
hell, post the best of what you have in the sticky pic thread
no need to thread jack anymore than I have.
Return to “Datsun 510 / Bluebird”
