DETurbine »
https://forums.nicoclub.com/deturbine-u8362.html
Thu Sep 09, 2004 5:08 pm
People that do the RB26 just think the only way of doing it and making it work is with the McKinney kit. Just like those that do the RB25 swap, they normally get the McKinney kit also. That is a total waste of money to me. The R33 cross works great, just will some times rub against the steering shaft, but there are ways to easily fix that.
I am doing the RB26 twins on my RB25 (with the stock R33 cross-member and mounts) and using the stock turbo manifolds with an adapter stud plate. I have looked and it will work, just would have to make your own down pipe. Going to be some what of a tight squize, but will work. What would need to be done with a LHD 240sx would be to keep the front turbos elbow on there and take off the back turbos elbow. You would have to build the down pipe to the front turbo elbow and also to shift around the steering rack a little and bolt back onto rear turbo itself. I have not done it yet, but will be over the winter.
With the RHD you will have no issues with the steering rack and down pipe. I actually wouldn't be suprised if you could make the stock down pipe to work like you can on the RB25.
Go for it man, that would be a great project. Nice to see you trying out a Nissan. Got any pictures of you honda?
Modified by DETurbine at 10:21 PM 9/9/2004
