BurntClutch wrote:2) I still have the longevity concerns I posted here , so has anyone made a boot for the pillowball ends? The only easy protection I can think of is to put a balloon over the end, but balloons don't hold up very well to the elements.
We have prolly well over 100 people running our tension rods problem free, some for longer than a year. The main problem that causes the lower control arm to break is that the polyurethane bushing is not designed to pivot nor is it designed to twist. The pillowball bushing we use in the SPL tension rods have full pivot and full twist motions in them. This gives the suspension no bind, which is what stresses the lower arm.
It's a far superior product, less flex, adjustability, and less binding. It even reduces weight over stock... using a billet aluminum shaft.
The only thing you need to change from factory, as far as installation goes, is to reduce the amount of torque you put on the nuts that go onto the lower control arm. They are supplied with lock washers, so there is no need for the high stock torque.
