The car is a 98 240sx Ka24de(t) I recently had the ac removed for a better cooling setup for the turbo and the windshield washer reservoir removed; however the shop that did it left a whole bunch of wiring clips disconnected. I have two clips from the harness going to the injectors a medium sized orange clip and a smaller black one. Then I have two other black clips on the driver's side in the engine bay close to the headlights.
The only light that is on is my airbag light and my horn doesn't work. (the ground for the horn is fine, I hooked the power source up to the battery power source and it worked; I also tried the airbag reset with no luck.)
I am guessing I have to complete the circuit? From the windsheild washer tank:(*Not sure what this goes to)the previous clip was located where my hand is reaching in this pic:this one is right behind the driver's side headlight (all of the lights work):Any ideas would much, thanks in advance
Modified by cleantune at 8:01 AM 4/4/2009
Modified by cleantune at 8:02 AM 4/4/2009
Modified by cleantune at 8:03 AM 4/4/2009
Modified by cleantune at 8:04 AM 4/4/2009
