Questions About Nissan Data Scan
sdkhalsa
Car: 94 Q45 06 M35
Just started using the Data Scan package on my 94' Q and had a few questions. What is the scale for ignition timing or do they just give you a reference point? How do you use the learning function on the active tests to update the IAC settings? The O2 sensors readings seem to jump around quite a bit; what is a normal reading? What is the best way to interprit the Air/Fuel gauge? Does this read an absolute value or just give a reference point of lean to rich functioning? Any special tips would be very much appreciated. Still looking around the internet for a decent manual or forum.
RyanH
Car: No more Q, just a 2006 Hyundai Sonata V6
sdkhalsa wrote:Just started using the Data Scan package on my 94' Q and had a few questions. What is the scale for ignition timing or do they just give you a reference point? How do you use the learning function on the active tests to update the IAC settings? The O2 sensors readings seem to jump around quite a bit; what is a normal reading? What is the best way to interprit the Air/Fuel gauge? Does this read an absolute value or just give a reference point of lean to rich functioning? Any special tips would be very much appreciated. Still looking around the internet for a decent manual or forum.
I've had a bunch of the same questions, and haven't been able to find useful answers as of yet. Some of the functions I'm afraid to touch until I can find out what they do and how to properly use them. Having the laptop on the seat with a fullscreen sensor display up generates a lot of looks driving around town.
Ozzie
Car: '90 Nissan 300ZX twin turbo - 2 seater
'99 Mitsubishi Legnum VR-4 Type-S twin turbo
'71 TA22 Toyota Celica (flat light)
'06 MK5 Golf tdi
and some motorbikes too
The o2 readout will jump around a bit until the sensors heat up...
I have the email address of the Programs creator and OBDI cable builder if you need it....
