Ramius83 »
https://forums.nicoclub.com/ramius83-u6643.html
Sun Apr 03, 2005 12:39 pm
Ok, about a week ago I started my RB26 swap into my S14.
Questions......
1. The gap between the radiator and the crankshaft/powersteering pulleys is slim to none. There is about a 2 inch gap. Obviously, my Flex-a-lite 220s will NOT fit in there because they are about 2 5/8" thick at the thickest portion. I have heard someone mention a "notching method" to install these or something like that. Can someone please elaborate more on this? At this moment, I don't think that I would be able to use these fans as there are too thick. What other fan choices are there for me? Can I use these 220s in front of the condenser as a pusher, and maybe try to fit a 10-12" single fan where I can fit it in between the radiator and the engine and have it run as a puller?
2. One of the water heater hoses on the RB26 has a sensor installed on it, and this sensor has a T plug that clicks onto the main engine harness. What exactly is this for? Is it needed? Reason being, the RB26 heater hoses are too small in diameter to meet up with the S14 lines. So, I was gonna use the old KA water heater hoses and the RB26 hoses, and just use a union between the the two to join them up. Easy and simple.....But I just need to know if I need to maintain that sensor or not.....
3. I used the McKinney mounts for the install, and I also purchased their driveshaft. Now, in order for the rear turbo water/oil lines to clear the steering shaft, I had to keep the shifter forward about 1/4", resulting in the whole engine sitting forward just a little. I am fine with that. However, when I installed the driveshaft, I noticed that when I slid the yoke all the way up into the transmission until it stopped, the resulting gap on the differential mount was about 1/4" as well, maybe a little more/less. So, I just slid the yoke out just enough to mount the driveshaft. Will this give me any problems, especially with leaks? I noticed that the whole yoke that drove into the transmission was the same diameter from beginning to end when I mic'ed it. So, in theory, I shouldn't have any leaks/problems because the whole yoke itself seals against the tailshaft seal on the transmission, correct?
Thanks all for your help with this. I am chugging along on this thing. I know the one thing that is gonna suck the most about all of this is the stupid @SS down-pipe and getting it to clear the steering column......Thanks again....
