Kansei240sx »
https://forums.nicoclub.com/kansei240sx-u21658.html
Sat Oct 11, 2008 4:42 pm
I've had the same problem with this manifold on a few customers car, including my own.
The only real way to deal with this problem effectively without modifying the manifold is loosening the wastegate spring or get a weaker spring and loosen it as much as possible, but enough to where it builds about 3 or 4 psi of boost. Use an Apexi AVC-R to control the boost to a perfect level adjusting the duty cycle of the solenoid. Basically the AVC-R cuts off the wastegate signal and opens it on and off very fast to modulate the boost pressure, doing this turbo response increases but is still laggy.
The best thing to do is modify the manifold right where the runners collect and have an extra tube to feed the wastegate tube and help divert exhaust gas and keep the turbine from creeping.
Its hard to explain, but the way your manifold is designed, which is the same as mine, has the wastegate tube at the bottom of the collector, which is the opposite direction of exhaust gas flow and actually creates a turbulence in the collector of the manifold and causes lag and poor boost control through the wastegate, thats where adding the extra pipe comes in.
These images are from another member here "Turbot304" but you get the idea.
Modified by Kansei240sx at 8:37 PM 10/11/2008
