redneckincanada wrote:Where was it rubbing? Front? Rear?
Inside of the wheel well I'm assuming.
What exactly did you have to cut?
Damn, if you rubbed with 1.5" spacers, I might be screwed with the 1"s I just ordered then.
How high did you lift?
Do you have any pics you could show of your rig that show how far out your tires are from your wheel wells?
Sure, here's how it looks. My sidewalls stick out far too as these tires are much wider than stock.
It was rubbing the bottom of the fender by the doors, I used the cutting disc to trim them back shown here
The outside corner of the tire also would catch the bumper when steering past, I used the knife to trim it back. It doesn't look like much but I actually took a lot off. (Pathfinder bumper may be different than my QX4)
It rubbed a lot on the front of the fender liner, here's where i heated it up with the torch and pushed it inward wearing thick gloves. It doesn't look good but it still functions as a liner and doesn't rub, so I'm happy
The 1" wheel spacers should actually rub less, I installed my spacers first, with stock tires and springs, and that created rubbing issues, fyi.
