questions about high flow cats
kirby26
Car: 2000 nissan maxima
hey i just had a few questions about high flow cats. i was told in order to put one on i was gona have to replace all of the o2 sensors, is this true? if so are there special after market o2 sensors you have to get? also how much of a difference does it make in sound and performance?
turbospotter
meh get a o2 stimulator for 40-50 bucks. Removing the cat/ getting a high flow only gives you top end sacrificing some low end.
maximaman
Car: 96 maxima
I didntnotice much of adifference after i put the hi flow cat in. I got short ram too so the difference off the line was unnoticeable. A little throatier sound mixed with intake. Once again... The sound was a pleasantly barely noticable gain... Along with the h.p. Very minor, almost not worth the hastle.
kirby26
did you have to replace your o2 sensors? the guy who is doing my exhaust says that i am going to have to replace them, but the place that is selling the cat says that i won't have to. i only ask cause i have to replace the old cat cause there's a leak in it. so instead of buying a stock one i was just going to replace it with the high flow. but those o2 sensors are $120 ea. i also just purchased an after market exhaust so i was going to have him put it on when he did the exhaust. i don't want to run just a straight pipes cause i still want to pass emissions. another thing, there are three cats on that car did you replace them all with the high flow, or just one?
kirby26
what does an o2 stimulator do? and is there anything else that i have to do, or do i just put it on and it just works?
maximaman
Car: 96 maxima
I think ur mechanic is feeding u b.s. The guys who did mine just drilled a hole in the pipe right after the cat and plugged in the old sensor. No problems
kirby26
good to know. im definately not going to that guy then. thanx dude. probly just gona grab one, i have to replace it anyway.
