OriginalWheelman wrote:Snow is all about tires. You want skinny tires to cut through the snow down to the pavement. Overly wide tires make you float on the snow. Ever seen the tires on a WRC car when they drive in snow?
Tires and weight. Best designed snow tires on earth aren't good for anything if there's no weight over them.
With my Ranger, I built a wooden frame to hold sandbags at the rear of the bed. Throw a couple hundred pounds of sandbags in to give your snow tires some leverage and you should be fine.
