questions about engine swaps
hicklinc
i have a 1995 240sx auto and i want to do an engine swap and change to a manual. i am thinking about puting a rb26dett in it what do you think and if i do go that route where should i buy it from the cheapest i've been able to find was 3000. i want to know high rated sellers of this and other engines. and what will i need to do the swap, i think i just need engine trans ecu uncut harness driveshaft and motormounts. and if you know any cheap place to do the install in fl.
sparksta
sup, i would try searching first. not good to make your first post one that asks questions that have been answered time and time again. just use the search button and see what you can come up with.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
XAT RACING can do everything you want for about $8600-$15000 other have done it but i hear great story's and have seen good cars roll out. Now honestly your gonna spend a crap load of money.
3500-5000 for engine setmckinney motor mounts 1500someone to install 500-1500intercooler and piping 500-1500exhaust 500then you have to do some simple engine replacement parts.
water pump spark plugsmaybe new radiatorupgraded fans new thermostatmaybe a new gasket kitclean your injectors
And be agressive about your engines history. Actually ask some of the guys here with thier rb26dett installs they're all over the place.
yellow_jacket
Car: 95 240sx
For $3,000 I would imagine you are going to be missing quite a few parts and it will probably come with the RB26 transmission. The RB25 transmission you will need for the swap can be hard to come buy so be careful.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
What would Jon Powel do? LMAO I think we need to get bumper stickers made.
hicklinc
it comes with this Motor AWD Transmission Turbo Wiring Harness ECU Ignitor Chip Mafs
yellow_jacket
Car: 95 240sx
You're going to need to source out a rb25 transmission
Saint
Car: 1999 Civic SI
Check out these guys.Note- that you get the RB25 tranney.
I found them here as a link.http://www.truboost.com/jdm.htm
Slo_240sx
Car: Mean Green LS1 S13. Caged and Backhalfed.
not a bad price, I got my rb25det clip with 4,500 miles for only $1,800
Nameless EJ6
Car: What the **** do you think.
Oh man, here we go again....
There is no such thing as CHEAP when it comes to this swap. Especially when you have a shop doing such a rare, extensive engine changeover as an RB26.
I'll redirect you to a thread I made a while back on 240sxforums.com
http://www.240sxforums.com/for...48599
Saint
Car: 1999 Civic SI
Start adding up all the things you need to buy to make this swap go right,and you will get depressed.You have to realy want this swap or just go for the SR20DET instead.Engine, ecu, whireharness and rb25 tranney $4200Mckinney mounts and drive shaft $1150down pipes $500Whire harness $350frunt mount Intercooler kit $800And on and on........I want to build a 240 with about 750HP. So, I am willing to go for it.
hannibal
Car: Red Line to Glenmont
Nameless, I thought of that thread when I read this...
mmatl16
Car: 240sx rb20 swap
if u really want a rb motor and dont have a spare 10 k to do it right then get an rb20 and ull be happy without declaring bankruptcy
Saint
Car: 1999 Civic SI
"WHE SHALL OVERCOME"Common! every body!
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
check out E-e motorsports there in Atl GA but they have done some pretty good work and they can source motors and any thing you need for your 240 needs also check out JHOT exports.http://www.jhotexports.comhttp://www.e-emotorsports.com
Saint
Car: 1999 Civic SI
Cool! a new shop in the A.I could care less about some big shop in Cali. Like I will drive there just to look arround.Why don't more of the mags visit other states?
BoostFab
Car: S13cp, S13fb, S14z
sean8564 wrote:check out E-e motorsports there in Atl GA but they have done some pretty good work and they can source motors and any thing you need for your 240 needs also check out JHOT exports.http://www.jhotexports.comhttp://www.e-emotorsports.com
eric at E&E is a very nice guy to deal with.
sean8564
1993 Nissan Silvia
I am using him to do my 25 install the Mounts from him are 350 the driveshaft 250-300the motor from JHOT 1800-2000labor 1200 not bad for a car that will out run most anything on the road
